Machine Vision
Can I use a PCI-1424 with a non-standard camera and build my own camera file?
I want to test a certain CCD which in non-standard and I want to setup the direct interface with it. My idea is to use a 1424 board and build the camera file.
(2,918 Views)
Technically, you can build your own cable and ICD (configuration) file for your camera. It can be very difficult, though. If the CCD is fairly standard, NI might be willing to create a basic ICD file for you which you can modify to do what you want. The best way to figure out what can be done in an ICD file is to look at ICD files for other cameras.
Bruce
Bruce Ammons
Ammons Engineering
(2,918 Views)
