08-30-2005 12:42 PM
08-30-2005 01:31 PM
09-30-2005 08:23 AM
09-30-2005 08:27 PM
I also think it is too small. You may be able to set the minimum character size to one, as well as min height and min width.
If you are inspecting a cluster display, you need to have a minimum of 2x2 pixels for each pixel in the display to get an accurate representation of the display. This will increase your character size. You may have to go with even higher resolution to get OCR to work on the display.
Bruce
10-03-2005 07:30 AM
