10-12-2017 03:03 AM
Hello. I am a student trying to track the motion of resin flow in a laminate using NI Vision builder. I took a video of the process and saved it as an avi file. However, if i try to upload it to vision builder, it gives me the error message " you have selected invalid image type" This confuses me because the avi file type is clearly stated as an acceptable format for video uploads to ni vision builder.
I read somewhere that i have to change it to grayscale, but doesn't that mean the video has to be uploaded first?
Solved! Go to Solution.
10-13-2017 08:05 AM
10-18-2017 02:55 PM
Are you getting this error message from the Simulate Acquisition step?
The Simulate Acquisition step should let you open AVI files. Insert a Simulate Acquisition step (located in the Acquire Images tab), and have the path point to your AVI.
-Christophe
