Machine Vision
Can i read the temperature datas from Lepton 2.5 camera(UVC) with pure thermal ?
Hello. I use IR camera system(the Lepton 2.5 IR camera(UVC camera) and pure thermal1). I can read the temperature datas from rasberrypy3.
So I try to read the temperature datas form labview vision IMAQdx. But I don`t read it.
I can see image from labview with IR camera system. But it is Y16 data format.
I think that Labview don`t get Y16 data format from IR camera system.
I see  Pixel format only BGRA 8 Packed and Vedio Mode 80x60 I420 / UYVY / Unknown / RGB24 9.00fps on NI-MAX
I see image to use I420, UYVY. But It don`t read the temperature datas.
And When i use Unknown, I see Error 0x80040217.
How can i read the temperature datas with lepton 2.5 camera and pure thermal1 ??
thanks.
(3,500 Views)
It looks like another forum issue.
Refer to https://forums.ni.com/t5/Machine-Vision/Camera-Video-Format-Not-Reading/m-p/3776575#M51024
Above link is not sure, but it can be helpful for understanding.
(3,469 Views)
Thanks for your answer. But I can not solve problem. I am designed for C library.
(3,466 Views)
I have the same problem. Have you solved it?
(3,246 Views)
What is unfortunate is National Instruments seems to believe that Y8/Y16 is not a valid format. It is however used extensively with thermal cameras with brand names by major companies. This has been going on for year after year with NI not recognizing Y8/Y16 as valid. For the life of me I don't understand their logic. Must be the company is getting to big (like microsoft)  to keep up with the Jone's and their customers are not important any more.
(3,122 Views)
