Machine Vision
Can not get Amscope USB 2.0 camera to display with IMAQdx
I am running LabView 2015 32-bit Academic instalation on a Windows 64-bit opperating system. I have the Vision Development Module 2015 SP1 installed as well as the appropriate vision aquisition drivers.
I am trying to aquire a feed from an Amscope MA500 USB- 2.0 camera (seen here: http://www.amscope.com/5-0mp-microscope-digital-camera-compatible-w-windows-mac-os.html) using IMAQdx and the Camera is DirectShow compatible.
I cannot aquire a feed from the camera and the "NI-imaqdx devices" folder does noty appear in the measurement and automation explorer.
There is a camera present in the NI-MAX - Devices and interfaces folder and it is called " Toupcam "cam1" ". When I click on it it gives me an error 0x8000FFFF (Undetermined error code)
I have tried the solution found in this post (http://forums.ni.com/t5/Machine-Vision/quot-NI-imaqdx-devices-quot-folder-not-showing-up-in-NI-MAX-U...) but it did not help.
Thank you for any help!
Graham
(3,707 Views)
How did u solve the problem? I have the exact same problem now..
(3,036 Views)
