Machine Vision
Can not load .pb model into Labview 2018
I am trying to load my model which is trained by SVM and using HOG to extract feature. I also used torch to save this model after training (.pb file). But I cannot load .pb file into labview. Here is my .pb file and images
Message 1 of 10
(7,370 Views)
Which version of tensorflow do you use ?
Message 2 of 10
(7,333 Views)
Please help me to solve this problem.Because I want to load this model (.pb file) to test my project. How can I do to load .pb file?
Message 3 of 10
(7,326 Views)
Do you know your tensorflow version ? You need to use suggested version, other version is not working.  Because I make self-training model .pb in another version in the past, my solution is run code in other place. Not expert in the DL vi.....
Message 4 of 10
(7,321 Views)
.pb file is a training character file which I used SVM algorithm in scikit-learn library. So how can I load .pb file into LabView to predict character ? Thank you so much
Message 5 of 10
(7,267 Views)
Should be like this
Message 6 of 10
(6,650 Views)
I had this problem while running the model, please can someone help me ?
Message 7 of 10
(6,348 Views)
Does the path of your pb model contain special characters?
Message 8 of 10
(6,338 Views)
Did someone solved this issue?
I have the same problem with exactly the same error :
I created my model with Google AutoML and exported in .pb file.
Message 9 of 10
(4,210 Views)
Clearly the issue is due to incompatibility with tensorflow version used in tensorflow LabVIEW API (TF1) and version used by Google AutoML to generate the model (TF2).
I think the only solution for now is to use python code to call model and then create a LabVIEW wrapper to call python code?
Message 10 of 10
(4,052 Views)
