Machine Vision
Can't find IMAQ Read Barcode function in vision acquisition-18.0
I can't find where the IMAQ Read Barcode function? I'm trying to make barcode reader using vision acquisition-18.0 newest version. There are many teaching videos, but they are using an old version of vision acquisition software. But I'm using 18.0 version.
(3,060 Views)
Accepted by topic author KusalThiwanka
There are two software packages:
- Vision Acquisition (VAS)
- Vision Development Module (VDM)
Image processing functions are in VDM. You have installed VAS...So you need to get and install VDM.. The version 18 doesn't matter that much.
By the way: Don't waste too much time searching for functions. Open the Block Diagram. Press "Ctrl + Space". This opens QuickDrop, where you can search for functions if you know their name. If an expected function doesn't show up, you haven't installed or properly activated the right module.
(3,025 Views)
Thank you very much Sir, I'm new to Labview.
I will try by install VDM.
Once again, Thank you very much for helping me.Smiley Happy
(3,022 Views)
