Machine Vision
Can the PXI-1428 CC lines be controlled through LV?
There are some LVDS lines on the MDR 26-pin connector labeled CC(1-4) for which I would like to know if these lines can be controlled programatically through LabView driver commands?
(2,938 Views)
Hi Robert,
The 1428 does not allow you to programatically control the CC lines.  However, the 1426, 1429, and 1430 boards do give you this control.
Best Regards,
Brooks W.
(2,929 Views)
