Machine Vision
Can we interface a mobile camera to a compact RIO using an USB port?
Dear all,
We are planning to connect a mobile camera to a compact RIO using a USB port. In case, if this interface is possible, is it the same way of capturing an image using NI IMAQdx functions. Earlier we have used a web camera interface to compact RIO and it has a frame rate constraint of 25 fps (640*480). Kindly let me know the possible way of interfacing a mobile camera with a cRIO.
Thanks and regards
Sukumar.
(3,014 Views)
Which camera are you planning to use ?
Sami Fathallah
Opto France
(2,951 Views)
iPhone 6 (8-megapixel )
(2,946 Views)
I am not an expert but as far as I know these camera modules are usually MIPI based, not usb, isn't it ?
(2,937 Views)
Accepted by NAGINENI
You cannot interface a Mobile phone camera with a Compact-RIO. Refer to the below link where It is menitoned that only USB3, GigE and Internet Protocol (IP) cameras are supported for use with cRIO-
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019KYuSAM&l=en-IN
Thanks & Regards,
Tarandee
(2,834 Views)
