Machine Vision
Can well visualize a Planar polygon.
HI,
I have the bondary points amd the plane equation of a planar polygn.using these can I visualize a planar plgn in Vision 2012.
Harsha.
(3,238 Views)
Yes you can visualize it but it's going to take a lot of time as you'd have to program it from the scratch.
The best i can think of is to segment your polygon and then use 3D parametric surface to visualize it.
www.xinstruments.com - Custom Software for Industrial Automation
www.hdrconverter.com - Picture processing made easy
(3,212 Views)
