Machine Vision
Cannot Install NI Camera File Generator
I'm about to put an updated NI Camera File Generator (2.0.4) up that will fix the following issues:
- Splash screen shows wrong version
- Add Attribute Dialog modality removes Camera File Generator from Alt+Tab selection
- Camera File Generator can't open certain older camera files
- Camera File Generator doesn't prompt to save when exiting if file has changed.
I'm waiting for documentation to finish, but hopefully in the next few days that will happen. Just wanted to let you know we are aware of this problem and will have a fix soon.
Thanks for your patience,
Brad
Message 11 of 23
(2,876 Views)
I just put the new NI Camera File Generator 2.0.4 that shouldn't hang anymore. The oldest version of NI-IMAQ that is supported with it is 3.5.1 (Installed with Vision Acquisition 8.0). The installer can be found here:
ftp://ftp.ni.com/support/imaq/pc/ni-imaq/cfgenerator/2.0.4/
Let me know if there are any problems.
Brad
Message 12 of 23
(2,836 Views)
This works for me, thanks Brad.
-Charles Lasnier
Message 13 of 23
(2,836 Views)
I still get this when i click on the setup
Message 14 of 23
(2,817 Views)
When I right click and give save as I get a "Setup.EXE could not be saved, because the source file could not be read.
Try again later, or contact the server administrator."
Message 15 of 23
(2,815 Views)
Just to try something...open Internet Explorer (I have version 7). Use this URL:
Click on Setup.exe (don't right click, just normal click on it), and Choose to Run the executable from the web page and choose to trust the web site. If that doesn't work, let me know if you can open the README.txt, or anything from
ftp://ftp.ni.com/outgoing/
Brad
Message 16 of 23
(2,807 Views)
The same problem exists. I am using ie 6.0
Message 17 of 23
(2,804 Views)
Can you open Readme.txt or anything from the outgoing directory?
Message 18 of 23
(2,802 Views)
Yes I able to open read me
NI Camera File Generator 2.0.4 requires NI-IMAQ 3.5.1 or higher.
Fixed issues for NI Camera File Generator 2.0.4:
- If NI-IMAQ 4.3 or higher is installed, NI Camera File Generator will not hang.
- Splash Screen has the correct version
Message 19 of 23
(2,801 Views)
I just put a zip file in the Camera File Generator 2.0.4 folder. Not sure what to tell you if you can't download that. I guess you could send me your email and we could try that if this doesn't work.
Message 20 of 23
(2,796 Views)
