Machine Vision
Cannot create a VI
I'm trying to build an application with Lab-view using IMAQ Vision; So far i want to create a VI that i've prepared using vision assistant. I click on tools>>create Lab-view VI.., and I get the message "National instruments LabView and IMAQ Vision not found" though i've both of them already installed; i've tried to install them again but the problem persists. Any ideas?
Thank you in advance
Uriel
(3,509 Views)
Uriel,
If you are running Labview 7.1 you may need to download the Vision Assistant Upgrade.
Search in drivers and updates for "Vision 7.0.1".
Good Luck
Dan
(3,487 Views)
It worked! Thank you very much Dan,
Uriel
(3,469 Views)
