08-19-2009 09:21 AM
I have installed ni labview and vision assistant on my vista-run laptop
Whan i am trying to create a vi from vision assistant,it shows labview and imaq are missing.
Plz try this
Thanks in advance
Solved! Go to Solution.
08-19-2009 09:43 AM
08-19-2009 11:43 AM
08-19-2009 11:45 AM
08-19-2009 11:45 AM
Try again, please (Message body is empty)
Andrey.
08-19-2009 11:55 AM
Its also important to know which version of Vision you have installed. For example, if you have installed LabVIEW 8.6, but Vision Development Module 7.x, then it will not work (as far as I remember). So, if you will install LabVIEW 8.6, then Vision Development Module 8.6, and then Vision Acquisition Software 8.6, then it should work.
Also it might not work if you will install at the first VDM, and at the second LabVIEW.
Andrey.
08-19-2009 08:23 PM
08-20-2009 01:19 AM
08-22-2009 10:00 PM
I have reinstalled labview and other components. Now the problem is solved
Thanks for help
