Machine Vision
Cant create a vi from vision assistant.error: labview and imaq missing
I have installed ni labview and vision assistant on my vista-run laptop
Whan i am trying to create a vi from vision assistant,it shows labview and imaq are missing.
Plz try this
Thanks in advance
Message 1 of 9
(4,873 Views)
Which versions LabVIEW/VAS/VDM you have installed?
Message 2 of 9
(4,870 Views)
Message 3 of 9
(4,859 Views)
I'm using labview 8.6 professional version
Message 4 of 9
(4,857 Views)
Try again, please (Message body is empty)
Andrey.
Message 5 of 9
(4,856 Views)
Its also important to know which version of Vision you have installed. For example, if you have installed LabVIEW 8.6, but Vision Development Module 7.x, then it will not work (as far as I remember). So, if you will install LabVIEW 8.6, then Vision Development Module 8.6, and then Vision Acquisition Software 8.6, then it should work.
Also it might not work if you will install at the first VDM, and at the second LabVIEW.
Andrey.
Message 6 of 9
(4,853 Views)
I've installed labview 8.6 first,then vision development module 8.6. Vision assistant was included in this package
Message 7 of 9
(4,833 Views)
I am still not clear how this is possible. Can you post a screen shot of what you get when you click create lv vi? Do you have multiple lv versions and vision tool kit for a previuos version?
Message 8 of 9
(4,823 Views)
Accepted by topic author anil89cs
I have reinstalled labview and other components. Now the problem is solved
Thanks for help
Message 9 of 9
(4,791 Views)
