Machine Vision
Cant see the Imaq pci-1407 card under the NT environment. tried creating as a new device but does nt appear as an option under Measurement and Automation
Having problems seeing the imaq card under NT. Noted the file pciimaq.sys is on the computer though doesnt seem to be actived by labview. Is it possible to add a new device to Measurement and Automation, There doesnt seem to be an option of adding the PCI 1407 card to Labview
Any ideas on where to go from here
(3,145 Views)
You may find the following website very useful: http://www.ni.com/support/imaq/
from here you can follow links for installing NI IMAQ hardware (PCI-1407), what to do if you cannot see your card under Windows NT, and if you need to, changing Windows NT PCI Bus Mastering. Follow the instructions and you should see your card. There are no options for adding the card from LabVIEW, and you should ensure that you install the ni-imaq driver first before installing any hardware. The latest version is 2.5.2 and is available for download free of charge from the ni.com web site.
If this does not help, please contact National Instruments Technical Support.
Sam
(3,145 Views)
