Machine Vision
Capture images from multiple cameras simultaneously with NI PCIe-8233
Hi Everyone,
I'm using the NI PCIe-8233 and 3 cameras Basler ace acA1280-60gc for a system of recognizing faults in objects.
For this I need to capture simultaneous images. How can I do it?
Best Regards
(2,567 Views)
Hello Diuda!
There are 2 ways of synchronizing the Acquisition from your cameras, as you can see here: https://www.baslerweb.com/en/products/cameras/area-scan-cameras/ace/aca1280-60gc/#tab=specs  Under "Camera Data" section.
1- Hardware synchronization:
Use the camera's Digital input as a trigger to acquire the images on the 3 cameras. all from the same source.
2-Use software synchronization by configuring on NI-MAX the trigger on the cameras in a way that the acquisition in camera A will be a Digital output that triggers the cameras B and C.
(2,509 Views)
