Machine Vision
Capture video with IMAQ from CMUcam3
  I have a CMUcam3 camera and I would like to capture and process the video using LabVIEW IMAQ utilities. I am not sure if this is possible without a lot of coding and re-flashing the camera board, but if anyone has already done this, please let me know how you went about it.
Thanks!
Rachael
(4,081 Views)
The CMUcam3 is an  ARM7TDMI based fully programmable embedded computer vision sensor. You can try Embedded Module for ARM Microcontrollers
(4,068 Views)
Hi Racheal,
You wouldn't be able to use the IMAQ or IMAQdx drivers with this particular camera; it would take programming in that embedded environment.
Cheers,
Marti C
NI Medical
(4,050 Views)
