Machine Vision
Capturing and comparing five different hand gestures to produce five different outputs
Hello
Im doing a project on labview where i have to capture 5 different hand gestures and compare and match them to produce 5 different outputs.
I have no hair left trying to accomplish this i have pulled it all out any help would be greatlly appreciated.
Im using a USB camera with the pictures coming out at 32bit RGB and lighting conditions vary in the room in which i am working. Which doesnt help the cause
(3,466 Views)
Hi AlanOConnell,
I hope you are well and do not have too much hair loss. My name is Larry and I am an Applications Engineer here at National Instruments.
I understand you are trying to do some image acquisition and analysis. Would it be possible to provide me some more insight into what you have already done and more details on how you want to analyse the finger gestures.
You can always upload your code in an attachment for me to take a look at also. I have access to USB cameras so should be able to replicate your system.
I look forward to hearing from you.
Kind Regards,
Larry Colvin
Associate Principal Engineer
Dyson Technology Ltd.
(3,447 Views)
