Machine Vision
Centroid
I have built an optical tweezer, throught an home made µscope and I measure the position of fluorescences balls ( 1µm to 200 nm) with 8bits labview centroid function.
My image are a 16bits and I oblige to cast into an 8bits Image before processing Centroid.
I would like to know, why a 16bits version doesn't exist ?
Does anyone know if we can programming a 16bits version, or Are others method exist to calculate the position in 16bits image on Labview?
PS : I have LV 8.0 and LV2010,
Thank you for all,
manu,
(4,378 Views)
Images types supported by IMAQ Centroid (NI Vision 2010) are: U8, U16, I16 and SGL.
Why do you need to cast into an 8bits Image before processing Centroid?
Andrey.
(4,375 Views)
Accepted by topic author Egerelli12504
Thank you,
I have LV2010 but I haven't installed yet, ... excellent thank you!
(4,368 Views)
