Machine Vision
Change color of ROI GROUP
can someone let me know if change colors of the ROI when I grouped them?
I want the oval ROI to be green or different color than RED.
Also, the oval has an extra ANGLE line. Does anyone know how to get rid of that?
Krispiekream
(4,150 Views)
(4,137 Views)
Accepted by topic author krispiekream
Hey Krispiekream,
In terms of getting rid of the extra line, I replied to your last thread. In terms of changing the color, unfortunately, ROI's are going to be all one color. You can change that color using a property node, but I don't think there is a way to change the color of each individual ROI (and still keep it an ROI and not convert the ROI to an overlay).
Message Edited by BCho on 03-12-2010 09:33 AM
Hope this helps.
-Ben
WaterlooLabs
(4,129 Views)
I see. Thank you so much.
i'll try working the math and see if i can manually remove it.
I am thinking to move toward the OVERLAY method since it has colored ROIs.
thank you so much for all your help.
Krispiekream
(4,125 Views)
