Machine Vision
Changing an RT EVS to a Windows OS one?
Is is possible?
The Colex Group
Lead Software Engineer
Certified LabVIEW Developer
(3,176 Views)
Hello jordankuehn,
This change should be possible, however there is not currently an officially supported process for doing so. The closest supported conversion process for embedded hardware that we currently have is for the our PXI Embedded controllers.
Here is a KnowledgeBase article regarding changing OS for a PXI controller.
Restoring or Changing the Operating System in a PXI-8171 Series Embedded Controller
http://www.ni.com/white-paper/3985/en#EXT%20CD
Cheers,
Joel
(3,164 Views)
