Machine Vision
Changing the template image constantly for pattern matching or shape matching.
Hi, I need to change the "template image" after I have done shape matching or pattern matching. The new template image will be acquired from a new image. How can I do that?
Thank you.
(3,145 Views)
You will need to repeat the training process for each template, just like the first template. The training takes a little bit of time, so a real-time system might struggle. Are you sure you need to continuously retrain?
Bruce
Bruce Ammons
Ammons Engineering
(3,145 Views)
