Machine Vision
Color Histogram bin
    can help in creating Color Histogram bin for the given input.
as similar to the attached image.
http://docs.opencv.org/doc/tutorials/imgproc/histograms/histogram_calculation/histogram_calculation....
Thank you
john
(4,377 Views)
You can use IMAQ Histogram located in the Vision and Motion>>Image Processing>>Analysis palette.
You can specify the number of classes used to classify the pixels to obtain the desired number of bins.
An example on how to use this function can be found at the following path:
C:\Program Files (x86)\National Instruments\LabVIEW\examples\Vision\Analysis\Histogram.vi
Christophe
(4,368 Views)
