Machine Vision
Color identification
Hi all,I'm new about Machine Vision.
I've a matrix (3x3) of circular case, that contain a liquid with a reagent that color it.
I can inspect it from the top, so I can see nine coloured circles.
I need to acquire the color for each case and assign for each position in the matrix
a code that dependes from the color in a given range.
Thanks to all that can address me in the right direction, with samples or tutorials.
laiseka
(3,586 Views)
Hi Laiseka,
I didn't understand what are you looking for, or better what software are you using to implement this task. Anyway i suggest you to take a look to this web documents:
Color Pattern Matching Example
Color Matching Example
Image Analysis and Processing
These developer zone could be useful to point you to the istruments and techniques you need for your application.
Please let me know if you need additional resources or if we could investigate moreover your needings.
Best regards!
M.C.
Matteo
(3,549 Views)
