Machine Vision
ColorMatching score
I intend to use IMAQ ColorMatch to compare the color of two defined ROIs. What I need to know is what is the proper way to use the array of score values? I understand that the array represents the scores for different regions but what am I looking for to check if the two ROI's color matches?
(2,989 Views)
Didn't realise there was actually an example on colormatching because it was removed from the NI Example Finder list after I saved it in other folder.
The example VI shows that the ROIs will be classified as "no match" if there is even one false in Match Flag for a given min match score. So I guess that answers my own question.
(2,987 Views)
