Machine Vision
Combining OCR and TTS
Hello everyone
Please someone combine OCR and TTS together so that I can get combined result of Text to speech conversion using OCR
(4,588 Views)
Assuming you can even get the LVTTS.LLB to work, you simply need to connect the OCR output to the TTS input.
Try this instead.
Download FESTIVAL from http://homepages.inf.ed.ac.uk/jyamagis/release/FreeVoices-WindowsBinary.zip
Put the extracted folder at C:\Festival  This is important, or Festival will not work.
Use the system Exec.vi
Wire [c:\festival\festival.exe --tts] to the command line
and wire [This is a test], or whatever you want to say to the standard input.
There are other commands that Festival supports for changing the voice, and other things.
Machine Vision, Robotics, Embedded Systems, Surveillance
www.movimed.com - Custom Imaging Solutions
(4,401 Views)
