Machine Vision
CompactVision system and 3x IEEE colour camera
I need to build an inspection unit with 3 IEEE 1394 colour cameras (1280*1024).
All 3 need to take an image every 100 ms.
So I have 3 simultaneous images every 100 ms.
Is this possible (bandwidth limitation).
According to my first calculation : no.
But I find it hard to believe that it isn't possible.
If it really isn't, what is an alternative?
thx
(3,689 Views)
You could use multiple firewire cards, with one per camera. I'm not sure if this would exceed the PCI bus limit, though.
Bruce
Bruce Ammons
Ammons Engineering
(3,656 Views)
Please check out the KB below. With this .exe you can calculate your bandwidth limitation for the Imaq IEEE 1394 driver
http://digital.ni.com/public.nsf/websearch/04E0D6266317021C86256D52005D4F3B?OpenDocument
If you cannot reach your specs with a CVS than, indeed, a Firewire card with multiple inputs can be a solution.
Regards.
JorisV
AE Belgium
(3,634 Views)
