Machine Vision
Compatibility Labview 2015 and Origin 8.1
Hello everyone,
I want to develop a post treatement programe with origin.
So in first i have to copy origin subVI to labview User.lib but when i enter in Origin for doing this operation i've got an error message whose telling me that : "No Labview is installed"
I've got Labview 2015 version 15.0.1 on my computer.
Do you know if there is any compatibility problems between Labview 2015 and origine 8.1??
(3,009 Views)
if you use active x for communicate  with orign you have to instal origin and elso active x of it (it is better your origin 9)
if you use toolkit  you have to install toolkit of origin inside labview
also here is machine vision part your question is irrelevant to this part
(2,980 Views)
Sorry for the post in the wrong part i just did a mistake but thanks for your answer !
(2,963 Views)
