Machine Vision
Compore two image and color the difference
Hi all!!
I have i problem.
I want create with labview a rudimental video surveillance software wirth camera balser 602f ieee394.
Now, i want compare 2 picture, A and B and create an other image C whit the different pixel are red.
Example: in image A i have a table. In image B i have a table with a pen on the table.
I want an image C  with the pen totaly red colored (different pixel).
Can i use machine vision to create this app?? Please help me!!
(4,049 Views)
Sure.  Store the initial image as a reference.  For each new image, use absolute subtract to take the difference between the two images.  Use a fixed threshold value that will ignore noise, and maybe do a little processing to clean up the resulting binary image (such as erode, fill, etc.).  Display the image using the binary palette.
Bruce
Bruce Ammons
Ammons Engineering
(4,035 Views)
Could you post an example please??
I have try but the resukt is wrong...
(4,023 Views)
Can you post samples of your image?
Waleed El-Badry MSc.,MCPD, ISTQB Certified Tester
Assistant Lecturer
Mechatronics Department
Faculty of Engineering
Misr University for Science & Technology
View Waleed El-Badry's profile on LinkedIn
(4,016 Views)
I have resolved, thank you very mutch work fine!! It's possible color only a part of image, for example using roi?? I want select only a little part of image, for example the center, and make in that part the control of different pixel... I post here the program where i want add the roi function! Thanks all for help!
(3,983 Views)
