Machine Vision
Concatenating NI-IMAQ Acquisition Images exampletriggered for each image.
In labview this example works with the 1409 board. However, I want to add a external trigger to the vi module that will wait for an external trigger 0 and to trigger each buffer. Ex. 5 buffers, 5 images, 5 triggers. Right now it free runs and I want it to wait for the motion control trigger. Also, it would be nice to have a horizontal instead of a vertical strip in the image window.
(2,920 Views)
Take a look at the example program linked here:
Low-level Triggered Ring
http://sine.ni.com/apps/we/niepd_web_display.DISPLAY_EPD4?p_guid=B45EACE3E01356A4E034080020E74861&p_node=DZ52492&p_submitted=N&p_rank=&p_answer=&p_source=External
It uses an external trigger and buffered acquisition - it should be what you need, so try modeling your VI from it.
-Julie S.
(2,920 Views)
