Machine Vision
Connection to port 3580
When i run VBAI2014SP1, and check on netstat, I see port 3580 open and there are multiple connections to it. it seems never-ending and try to use all the ports. the rate of the connection to 3580 is quite high. after using 65535 it roll-over to 1 and keep counting up. Anyway to get rid of this weird behavior?
Message 1 of 1
(3,412 Views)
