Machine Vision
Construct Image 3 taps 16-bit Camera Link Camera using NI 1483
I am facing a similar error.
When I run the example "10-tap 8-bit with DRAM" on a PCIe-1473R I can acquire burst of frames without problem, however when acquiring frames continuoslyI run into "Error -8999: DMA Write Timeout".
Anyone have ever had the same problem or has suggestion to solve it?
Giuseppe
Message 21 of 21
(889 Views)
