Machine Vision
Contour analysis
Hello everyone !
I'm having some problems with this function contour analysis. This function is functional extracts a single, best contour from an image. But I want to take out many contour. Is there any way to get it out?
Thank you.
(2,890 Views)
Can anyone help me solve this problem. I'm stuck on this issue
(2,823 Views)
vuka,
I know that this post is pretty old, so not sure if you've figured it out already. I'm a little confused about what you are trying to accomplish. Do you want to analyze each of the shapes in this image separately? If so, you will need to call 4 different Contour Analysis functions and specify a different ROI for each on that only contains the one shape you want to analyze.
-Jordan
(2,737 Views)
