Machine Vision
Control Casio EX-F1?
Can LabVIEW connect to and control a Casio camera?  If not, can it control the software available from Casio which controls the camera?
Thanks!
(If I have posted in the incorrect forum please direct me to the correct forum)
(3,875 Views)
The first step in determining National Instruments compatibility is to determine the camera bus type. Have a look at the following article:
Is My Camera Supported by National Instruments?
If the bus type is not compatible, then LabVIEW can call external code like C/C++ DLLs, .NET Assemblies, ActiveX code, scripting languages and executables. If the Casio software supports any of these ways, then you should be able to use LabVIEW.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,850 Views)
