Machine Vision
Convert IEEE 1394 Cameras color image into greyscale
How can I directly convert a color image (RGB32, live image from IEEE 1394 cameras) into greyscale image (U8) ?
Because the find object function cannot used at color image (RGB32)
At that moment, I can only save the color image into file, then open this file as U8 format.
my camera is PROSILICA EC1380C
interface : IEEE 1394
driver : NI-IMAQ IEEE1394 for cameras
Thanks !
(3,255 Views)
Hi Metron,
If you have Vision, you can convert a RGB image to grayscale by using the IMAQ ExtractSingleColorPlane and extracting intensity or luminance.
Ryan M.
National instruments
(3,244 Views)
Hi Ryan M,,
It is ok now, thanks !
Metron
(3,228 Views)
