Machine Vision
Convert a RGB Imaq image to an array
Hi
I´m using Lab View 8.0 and Imaq 3.0. I have a 32-bit RGB Imaq image from my camera.
I need the RGB value from each pixel of this image. To get the pixel value I want to convert the image into a 2D-array without vision.
I tried to do this with "ImageToArray" vi but I get an error: Invalid image type.
Perhaps you find a better solution, without convert the image into an array.
Could you help me?
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(6,789 Views)
"IMAQ ImageToArray" does not work with RGB images.
"IMAQ ColorImageToArray" supports this image type.
Best regards, Guenter
(6,783 Views)
Does this Vi work without vision?
--Signature--
(6,783 Views)
Sorry, because I have IMAQ Vision installed on my PC. It contains (of course) the VI "IMAQ ColorImageToArray".
Unfortunately I therefore cannot check, if a pure installation of NI-IMAQ 3.x also installs this VI to LabVIEW.
But if I remember the contents of the palette installed to LabVIEW by NI-IMAQ correctly, the VI comes with any version of NI-IMAQ.
(6,775 Views)
