Machine Vision
Coordinate transformation
A telecentric lens would fix the scaling issue, but they usually don't have a large depth of field.  You would only be able to move a small distance before being unable to focus.
I would just figure out the mm/pixel for several heights, and see if you can fit a curve through the points.
Bruce
Bruce Ammons
Ammons Engineering
Message 11 of 11
(504 Views)
