Machine Vision
Copy an image from display 1 to display 2 when there is an object.
Hello to everyone.
First of all thanks a lot for reading this post and being able to help.
 I have two displays on the front panel (display 1 and display 2).
Display 1 images that captures a Basler camera is displayed, which takes a picture each 1 second. On this display there is a line that measures an object.
What I would like is that if this measurement is greater than 2 pixels, then that image is copied to the display 2 and stay there, while the display 1 continue to show captures every second.
How can I copy the image from display 1 to display 2?
Thanks a lot!
Message 1 of 10
(4,732 Views)
have two image indicators and connect same wire to two indicators only if it matches.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 2 of 10
(4,723 Views)
I think that will not work.
Because I think I have to use IMAQ create ofr each image... So I need two if these VIs.
Message 3 of 10
(4,717 Views)
can you share the image and the code which you have created.
Message 4 of 10
(4,714 Views)
I have to display the image and to move a ROI in that display 2.
I do not if I am explaining well
Message 5 of 10
(4,712 Views)
So then in this case I need a buffer or neither?
Message 6 of 10
(4,711 Views)
yes of course you need a buffer.
How about using IMAQ Copy?
Message 7 of 10
(4,709 Views)
-How are you getting images and displaying in indicator?
-How many IMAQ Create are you using?
One simple case: If you are using single buffer then you can pass that image to Image indicator with snapshot mode which will create local copy of image.
-Another way is one buffer to get images continuously and overwriting the buffer and another buffer and use IMAQ Copy
uday
Message 8 of 10
(4,708 Views)
Accepted by topic author A.Salcedo
Message 9 of 10
(4,704 Views)
Thanks a lot!
It works!!
Message 10 of 10
(4,574 Views)
