01-03-2012 03:28 AM
Hello.
I am trying to get images from an Atmel Aviva M2 Line Scan Camera via LabView 2009. The board is a Coreco X64-CL_iPro with one port.
The camera is working with the supported Software which is a little old unfortunately.
If I try to configure the cam with MAX an error code " 0xBFFF69000 not enough memory" appears. As there is another forum entry where this error was caused through driver issues, I think this might be the same here.
Is there a solution for my problem e.g. a LabView driver for this board or to use an up-to-date LabView version?
Thanks a lot for any suggestions.
Harry
01-03-2012 05:53 AM
Alliance Vision provides a driver compatible with you board.
http://www.alliancevision.eu/products/softwares-drivers/drivers/112
Regards
