Machine Vision
Corrupt VI after saving with LV and vision module 8.6
I have a project in Labview 8.2.  I can open and run it well in Labview 8.6 but if i saved the main VI i cannot reopend it.  Labview crash when trying to open the file after saving it.  The original file is also the double size of the new one.  The error says that the module nivision.dll crash.  Here's the error
AppName: labview.exe AppVer: 8.6.0.4001 ModName: nivision.dll
ModVer: 8.6.0.49152 Offset: 00014715
thank you
Message 1 of 8
(4,408 Views)
This is probably related to a corruption that may have occurred in the upgrade. Do you have any custom controls? Do you have subVIs that you can save that do not cause it to crash?
Vince M
Message 2 of 8
(4,387 Views)
I have 2 or 3 customs controls and i can save all my VI without problem exept one
Message 3 of 8
(4,370 Views)
I would suggest remaking those 2 or 3 custom controls in 8.6 and replace them in the VI that you are having touble with. One or all of the custom controls are probably corrupt from the upgrade.
Vince M
Message 4 of 8
(4,360 Views)
I had a similar problem when I upgraded to 8.6.  I found out that the guilty control was a reference to an image control that I was trying to pass to a subvi.  Since it isn't possible to create this control directly, I had dropped an image control onto a reference control to create it.
I had used this control several places in my program.  I ended up making it a strict type definition, which reduced it to one control to repair.  By deleting and recreating the control, I fixed the problem.
Bruce
Bruce Ammons
Ammons Engineering
Message 5 of 8
(4,354 Views)
I recreated my 2 custom controls and it did not work.  These controls are only for a state machine (Enum control) and it does not have vision control in it.  I also don't find reference in my code.  To create an image control I right click on any vision funtion who have an image input and choose create-->control
Message 6 of 8
(4,346 Views)
How big is the VI that has problems saving? I'm still convinced that this is a corruption problem. If your VI is not too big I would suggest that you start deleting and replacing VIs. You say that you have already done this with the custom controls. If your VI is too big I would suggest starting with the vision VIs. If you find which one was corrupt then please post that so we can have the documentation and see if this has happened more than once.
Vince M
Message 7 of 8
(4,310 Views)
Its a huge program. Thank you for your help but I reinstall LV 8.2 and everythings works well now
Message 8 of 8
(4,299 Views)
