Machine Vision
Could you please calculate expression
We would like to calculate the expression as follows:
                                 N       N
                                 Σ    Σ   (i+j-2μ)3 p(i,j)
                                i=1  j=1
N is constant equal to 7, μ is variable, and p(i, j) is array,
Could you please tell us how to do it by Labview.
Thank you very much.
With my best regards,
Panmanas
Message 1 of 21
(5,439 Views)
Is this relevant topic to image processing?
Waleed El-Badry MSc.,MCPD, ISTQB Certified Tester
Assistant Lecturer
Mechatronics Department
Faculty of Engineering
Misr University for Science & Technology
View Waleed El-Badry's profile on LinkedIn
Message 2 of 21
(5,429 Views)
 Hi panamas,
                     Did you try using the formula node?
Message 3 of 21
(5,426 Views)
muks is very correct. you can try the formula node (if you are familiar with MATLAB syntax)
Assistant Lecturer
Message 4 of 21
(5,408 Views)
Actually, the formula node uses C syntax.  The mathscript node use Matlab syntax.
Bruce
Bruce Ammons
Ammons Engineering
Message 5 of 21
(5,395 Views)
Dear Waleed EI-Badry, Muks, and Bruce
Thank you very much for you to try to help me.
It is image processing related about texture of the surface.
We tried Formula in Labview but we could not get the result because p(i,j) is array and we need to do loop but we dont understand how to do loop.
So we think we had better ask well experience person that can do it very faster than us.
We dont understand C or Matlab.
Please kindly help us again.
Panmanas
Message 6 of 21
(5,384 Views)
Dear panmanas,
        please find the attached vi that would evaluate your expression. I hope this helps
Assistant Lecturer
Message 7 of 21
(5,366 Views)
Dear Waleed El-Badry
Thank you very much indeed. we shall try and study what you do for us.
Please have merry time.
Panmanas
Message 8 of 21
(5,341 Views)
I'm not a LABVIEW expert (Mucks is much better than me Smiley Very Happy
My expert domain is in Visual Studio.NET. Even though, I'll be happy to help you with LABVIEW as much as I can.
Assistant Lecturer
Message 9 of 21
(5,333 Views)
We have studied your solution and tried to follow you. But our Labview is version 8.0. So we still have problem. We still have broken wire.
Could you please clarify for us again to correct our code in attached file.
Panmanas
Message 10 of 21
(5,298 Views)
