Machine Vision
Create Image
Good day,
I again ask one, and how to represent a matrix as an image in gray tones of black and white, my matrix consists of 90 columns and 3000 rows, this matrix as an image 128 * 128 needs.
someone has an idea or a beispiles Program.
Thank you and look forward to speedy answers
(4,140 Views)
Do you mean you want to extract a part of an image? If english is not your first language then post in your native language.
(4,137 Views)
Well there's an IMAQ Array to Image block which, "Creates an image from a 2D array."
However the array you are using (90*3000) is quite a bit larger than the 128*128 image that you want, so you'll need to work out how you want to convert between the two sizes.
edit: There is also an IMAQ Image to Array block if you are trying to go the other way.
Message Edited by Hornless.Rhino on 20-04-2010 11:31 AM
(4,099 Views)
