Machine Vision
Creating custom camera files (PCIe-1430 with dual Basler acA2000-340km)
Hello
I need complete camera file for my Basler acA2000-340km area scan camera.
Although NI application engineer help me a lot, it's not perfect.
Recently modified camera file for PCIe-1430 shows only left half area of total resolution.
At the moment, I'm trying to set up two of Basler cameras over real-time target PC environment triggering from RTSI DAQ board.
BTW, is this 'Industrial Camera Advisor' option 4 request support?
Regards
Cris
(4,425 Views)
What tap geometry do you have the camera configured for? I would imagine it defaults to one that requires medium or full configuration CameraLink while the 1430 is base configuration (so you'd be missing data). You should use Basler's Pylon utility to configure the camera into a tap configuration that only uses base configuration.
Eric
(4,396 Views)
Is the Basler acA2000-340km compatible with the PXI-1428 camera link card?
(4,299 Views)
