05-22-2008 10:32 AM
05-27-2008 11:52 AM
10-01-2008 03:10 PM
Please, I have urgent question, I hope to assist me to solve this problem…
In Vision builder V. 3.5, I need to display the list menu in User Interface (UI) window inside vision builder, that this list menu display my available firewire (IEEE 1394) cameras and let us to select one of them…
Waiting your kind replay as soon as possible..
Thanks for your attention..
My best regards
Haider Al-Juboori
10-02-2008 03:07 PM
Hi Haider,
I do not know if this is possible. Essentially you could use a Run LabVIEW step to populate a list of cameras connected to the PC but even after choosing one of those cameras I don't know how you would get that selection into the Acquire Image step. This step gets configured within the GUI that appears after adding it to your inspection. You then manually select the camera. How were you thinking of doing this?
You could always have the user double-click the Acquisition step and manually select the camera from the list.
10-03-2008 04:42 AM
Hi Michelle,
thanks for your kind replay...
OK, please, can you tell me HOW...I can populate a list of cameras connected to the PC in LABVIEW?
Hiader
10-06-2008 10:47 AM
Dear Hiader,
This Knowledgebase and the Developer Zone example linked from it describe how to do what you ask:
Programmatically Finding Attached IEEE-1394 Cameras
http://digital.ni.com/public.nsf/allkb/AD1041C9B4B27240862570DD0068605B?OpenDocument
Basically, you want to use the IMAQdx Enumerate Cameras VI to return a list of connected cameras. I agree with Michelle that I don't think it's possible to pass a user selected value from this list to the Acquire step in VBAI to select your camera.
You MIGHT be able to set up different states in your inspection, one for each camera. Each state would have a different acquire step that was specifically setup for that camera. You would make a decision to transition to the appropriate state based on the user selected camera (all the user selection would have to be handled in the LabVIEW step, or from a Dialog box in VBAI). Note that there are many potential problems with this approach, and if I were completing a project with a user interface to select cameras, I would migrate my inspection to LabVIEW and complete my GUI (graphical user interface) there, where I had more flexibiltiy and control to do what I wanted.
Hope this helps,
~Nate
