Machine Vision
Customize default CVS FPGA code used with VBAI
I would like to customize the default code running on the FPGA of a CVS unit that is used by VBAI 3.5. We need to add a special funcionality into the FPGA that will run in parallel to the inspection scripts. I need to know:
1. where can we find the source code for the FPGA that is used by VBAI 3.5
2. how to builed the customized code (and if there are any recommendations in regards of communication between VBAI and the FPGA)
3. how to deploy the customized code on the CVS unit (the best thing for me would be a new updated image of the CVS for further deployment on more CVS units in future)
Please give me some clues, because I was not able to find anything in this regard on the ni.com website.
Martin
Message 1 of 1
(3,322 Views)
