Machine Vision
DALSA Pirahna camera conf file
modify this part of the .icd camera conf file in order to be able to use PRIN
exposure
control methode:
Pattern {
Action (PG) {
Line (0) {
Start (Low)
1, 10
Line (1) {
Start (High)
65, (PRIN)
Line (2) {
Start (High)
Line (4) {
Start (High)
1, 25 * 1000000 / (Line Rate)
RepeatSource (Fixed, 1086)
Timebase (1)
(3,085 Views)
If you're experiencing problems with a National Instruments camera configuration file (.icd) then it is best to contact a National Instruments Applications Engineers (www.ni.com/ask) rather than trying to troubleshoot it on your own. Right now, there is little public documentation on camera files, so trying to modify them usually leads to headaches.
(3,085 Views)
