Machine Vision
DT frame grabber
Hello i have a DT frame grabber DT3133. i want to use this in labview. I tried activeX but it didn't worked. Can somebody help me
some suggestions? thanks
bob vda
(3,926 Views)
Hi Bob,
I wasn't able to find something on our web site. I also check on Google and on the web site of the maker of your Board but without any results. Maybe this link but I'm not really sure it is especialy designed for your board....
If it doesn't help you, you should ask to the board maker if it's existing any drivers or ActiveX to communicate with LabVIEW.
Julien Roland - District Sales Manager
NI Belgium - Technical Support
Don't forget to rate a good answer
(3,880 Views)
