Machine Vision
Damaged icd file for Pulnix TM-1300
Have downloaded and installed icd file in proper directory for Pulnix TM-1300. Using Max v2.0.3.6 and IMAQ v2.21. When I perform file/camera/open the icd file in MAX, I get a damaged file error message. Other default icd's open fine. Can anyone verify if file is damaged?
(3,377 Views)
I just tried the Pulnix TM-1300 from the ftp site and it opened up without errors.
The only difference is that I am using NI-IMAQ 2.5 You may want to upgrade to the latest version of NI-IMAQ. http://digital.ni.com/softlib.nsf/websearch/CA931B93AD556D38862569BA0073D74D?OpenDocument
It's unlikely that the camera file is damaged, you can view the files in notepad as they are just ASCII text files.
Ken Sun
Applications Engineering
(3,377 Views)
Ken:
Thank You- upgrading to IMAQ v2.5 solved the issue. P. Nico
(3,377 Views)
