Machine Vision
Delete one overlay out of multiple ROIs
I would like to delete one specific rectangle overlay ROI out of many overlay ROIs. My main purpose is that changing specific ROI's location. In order to do that, I can add a new ROI by clicking on the image. However, even though I delete previous one from array of ROIs, previous ROI is still visible. I think it is regarding "IMAQ Overlay ROI". Do you have any idea to delete the ROI or change its location? Thank you in advance.
(2,297 Views)
Accepted by topic author oguzk
When working with overlays, you can assign them to groups and delete specific groups.
If you work with ROIs, you can use IMAQ Ungroup ROI to split the ROI into individual countours, delete the desired countour, reassemble remaining array with IMAQ Group ROI and write it to the Property ROI. It works for me.
Good luck!
(2,290 Views)
Hello p4keal,
Thank you for clear answer. It worked for me too.
(2,249 Views)
