Machine Vision
Detect dark 'needle' on light background (360°)
I'm not sure but you can try overlaying Gauge Indicator on to image and make the needle invisble.
uday
Message 21 of 27
(3,741 Views)
Haha, it's funny that you mention it, because I (as an beginner) tried that and it worked, BUT it is far too inaccurate, is there an different solution?
Message 22 of 27
(3,737 Views)
never mind, It is not important anymore:)
Message 23 of 27
(3,641 Views)
Now it becomes interesting, the deviation is at some points too much, as well negative as positive. That's because of the resolution. Is it possible to increase the resolution, p.e., make from every pixel four??. (pixel overlap?)
Message 24 of 27
(3,624 Views)
It isn't the resolution.  It is more a perspective thing.  For accurate measurements, you need to be looking directly at the needle from a perpendicular position.  The needle has to be flat against the surface, and it needs to have the same shape in any position.  The lighting has to be good so there are no shadows.  I would not expect to get fantastic measurements from your setup, so it may be the best you can get.
Bruce
Bruce Ammons
Ammons Engineering
Message 25 of 27
(3,608 Views)
He gives at 8 points the correct value, at 12 oclock, 3, 6 and 9 amd between them, so the circle isnt really a circle, and thats because of the resolution, so it aint gonna be exact, but the higher the resolution the less the deviation. If I cant increase the resolution, I will try multiply the array with a handmade array as a filter. (Basicly I thougt that every pixel is a constant N degrees, but at some points (8) there are more pixels in the array), so the deviation is because of the calculation based on a constant index/degree
Message 26 of 27
(3,605 Views)
I did it!, I created an array (sine waveform) and added it to the other array to compensate the deviation, and it worked perfectly!:) The max deviation now is only 1 degree, thanks everyone for the responses
Message 27 of 27
(3,576 Views)
